Walbro Fuel pumps - thru Ron Gregory
http://members.home.com/syclone/APE/
Cheapest and most reliable intank fuel pumps you will find - ANYWHERE
the top of the line high pressure 255lph pump is only $108 shipped
and the service was great.
While the 255 is a little noisier than stock - it is a factory issue type pump so it will last forever and it will deliver enough fuel flow at pressure to properly operate a dry nitrous system which can see as much as 100psi of pressure.
Surprisingly easy to install too
GREG
Turbonotch on corral.net
Different defined - Mustang Notchback with a Turbocoupe Engine and....
NO MERCY
87 Notchback, 87 TC motor
T3 turbo and full 3" exhaust with a dummy 2" tailpipe for a "decoy", Starion IC - Saab bypass, MSD6AL & "Launch Control", 93 Cobra T5, B&M shifter, Ram 6puck Kevlar Clutch, 8.8" 4.10 tracloc rear, BFG drag radials
BUT only 14.6 @ 96 so far
Coming soon: a ranger roller and full power tuning and thirteens before spring
Living isnt to arrive at the grave safely in a well preserved body, but rather skid in sideways, totally worn out, shouting 'holy sh**, what a ride!'
I agree... I bought a 255 high press pump from Ron, and it arrived in 3 days. It is quieter than the on the way out pump I replaced!
Jeff Korn
86 Tbird 5.0: intake, exhaust, valvetrain, 100 HP NOS, ignition, gears, suspension, etc., etc. // 88 Turbo coupe, Intake & exhaust mods, Garrett T3 turbo, 18 psi, forced air intercooler, bypass valve, Ranger roller cam, etc., etc. // 91 Escort winter, work car // 00 Windstar (wifes vehicle)
Jeff Korn
86 Tbird 5.0 - lots of mods / 88 Turbo Coupe - lots of mods / 05 Taurus Duratec / 04 Taurus Duratec (wifes) / 02 Grand Prix GT
I like the noise it sounds like it means business!
Is there a contact number for Ron Gregory?looking for a walbro 400 lph pump.
(04-13-2020, 07:23 PM)Wesley easter Wrote:  Looking for a Walbro 400 lph pump.
Stinger has 'em for 130 bux = LINK   [Image: confused0024.gif]
BTW......WELCOME to TurboFord, Wes!  [Image: happy0034.gif]
(former)  2.3T '78 Courier ~ (current)  2.3T '87 Ranger & '82 Mazda B2200 (smog-exempt diseasel truck)
The original post is from 19 years ago. Odds are the info is no longer valid Wesley.
|STINGER PERFORMANCE| 2.3T Parts, Swap & Tech Articles |FAQ| -FORUM-|
|->PiMPxs & PiMPx ECU\'s<-| SVOx3, Turbo 06 GT
