What does it feel like when your clutch starts to slip?
Everythings all cool at take off and while shifting.
If I get on the gas, the car speeds up and then if feels like it looses something.
I can still hear the RPM's going up, but it feels like I pushed in the cluch pedal for a split second, then the powers back again.
87 Turbo Coupe, 5-speed, Tangerine exterior,
Shaved door handles, locks and emblems, Tiger interior, Autometer gauges, painted trim pieces (matches exterior), monitor & PS2, pony wheels(white)
Sounds like your clutch is just starting to go.Try to refrain from playing boy racer & it`ll last a little longer.
What's involved in changing the clutch?
How much is a good clutch run?
I'll be doing it myself...
I'm not sure about clutch prices, check out www.jegs.com, or www.summitracing.com for prices. Changing the clutch isn't too difficult, but getting to it can be a pain sometimes. The engine and trans are bolted together as you may suspect, and getting between the two isn't always a funbag of fun. It's gonna take a little time, but you're better off doing it yourself than paying a mechanic.
Well, I am a mechanic, but I've never done a clutch before. Do you have to take out the tranny? Or just unbolt from the engine and get in there somehow?
If you don't care about taking a couple of day's worth of wear off, you can check it by puttin' it in 5th, revving it up and popping the clutch. A good clutch will kill the engine - yours probably won't! [Image: frown.gif] Check with pnrvegas - I understand he's got some good deals on the Star (?) clutches that a lot of the guys swear by. [Image: smile.gif]
Tiny avenger has a nice clutch kit. You can get it with an aluminum fly wheel if you want. It's half the wight of the stock one, so faster spool, faster revs= [Image: biggrin.gif]
Elliott
1986 XR-7 turbo
Starion intercooler waiting to go on, ready for 3" DP, gillis valve, new exhaust, adj FP regulator, big VAM, LA3, and a thorough porting.
"Just the ramblings of a free-range brain..."
" Auto racing, bull fighting, and mountain climbing are the only real sports ... all others are games."
- Earnest Hemingway
hey if u cant leave some fat marks on the pavement, and still go over a 100mph ur clutch is ok,,,,,
It`s not really hard per say Joneser, just time consuming.It all has to come down,driveshaft, tranny, bell housing,clutch set-up,flywheel. Put in a new rear main seal,& check flywheel out for surface cracks & shape of ring gear on the perimeter. You will prob need to have it resurfaced but if the ring gear is all nicked up,you`re better off replacing it entirely.Make sure a clutch alignment tool comes w/new clutch set-up.if you can do this @ work w/a lift,tranny floor jack,it will be MUCH easier.
The hardest part is getting the tranny to move the last 1/4" to mate with the motor. The input shaft is a tight fit with the pilot bearing.
66 Sprint 200: Smokes tire 125ft! ...and... 87 LX notchback: 85.5 SVO motor, .020 over TRW pistons, O-ringed, head studs, A237 roller cam and adjustable pulley (4 degrees advance), ported E6 manifold and intake, T3 turbo with .63 A/R exhaust housing, 3" Dynomax exhaust w/ cat, 3" VAF meter, SVO intercooler, adjustable fuel pressure regulator, 190lph fuel pump, 5spd, RAM Powergrip 6-puck kevlar faced unsprung hub clutch, 3.45 limited-slip, GT turbine wheels
Jon Keeling
87 Turbo Notch - excessive body rot
http://www.jonkeeling.com/sig.html
