XR4Ti brake pedal assembly
Does anyone have a picture of or can describe the orientation of the spring, washers, and spacers on the brake pedal shaft? I am reassembling the clutch and brake pedal assembly and I forgot to take a picture of it before I disassembled it and the service manual is no help.
I thought I had it correct, but the groove for the clip is covered by one of the spacers. So I am a little stuck at the moment.
1992 5.0 notchback - 11.507@121.08
1986 Merkur XR4Ti - 294rwhp/315ft-lbs
