do you have to run water through the turbo if it has the lines or can you just plug them?
And you don't have to plug the holes either, unless you're worried that some little spider might die an ugly death after warmup.
[Image: smile.gif]
C'ya - RAY
Former 2.3T Courier (carbed/blow-thru) & soon turbo Ranger
If u run w/o the water, then u may want to run a good full synthetic oil. They generally have a much higher flashpoint than conventional oil. Which means it is less prone to burning up when passing thru a hot bearing, especially on shutdown if u forget to let the engine idle.
I religiously let my '84 (no water cooling) idle at least 30sec b4 shutting down. I had her up to 154k mi. I always used full synthetics.
Good Luck
'86 SVO Stock exc for Racer Walsh Ultralite Adj Cam Sprkt & Mallory TFI coil, Reg Bosch Plat & K&N replcmnt - 161k mi, runs strong
- Had '84 SVO for 90k - Stock except GW camber plates, relocated oil filter (for 1qt), Bosch Plat, K&N rplcmnt & Mallory TFI coil
- Had '85 TC 5 spd - Stock, Bosch Plat & Mallory TFI coil
- Had '74 Nova - Teenage Hot Rod, 350 ci, Edlbk Perf Pls cam & manfld, Comp Cams 1.6 roller tipped rckr arms, Mallory Promstr coil, std 1-5/8" hdrs, no traction
- Had '77 V8 Monza - real poor man's SVO, stock 305 w/ dual exh, no cat, fun - greatest handbrake-turner ever made
- UTA Formula SAE '93-'95,'97 & '99. 1995 Champion
'86 SVO - RW Adj Sprkt & Mllry #29214, Lucas inj, K&N rplct, Wlbr 155, KB Extrem Mtrx - 186k mi
-Had '84 SVO & '85 TC, 1995 FSAE Champ - UTA
The lines are also supposed to help allow you to just shut it down after full throttle runs instead of letting it idle down for 10-30 seconds or so. The water will continue to cool the turbo down when the car is stopped while oil MAY cook. Its up to you really....how much trouble is it to route the water lines or do you want an extra place to burst holes???
-Paul North-
'88 XR4Ti- 18psi no intercooler with bypass valve, 3" exhaust, full suspension etc.
'88 Mustang Gt- boss block 347, .688 solid roller, TEA canfield heads (306/250 @.700) etc
-Paul North-
Here is what Graham Goode says about the water lines on their Cosworth RS500 turbos:
Quote: The GGR RS 500's didn't use water cooling for the bearing housings, why not?
Water cooling of the bearing housing is a good idea for a road car. When the turbo is operating at high boost pressures, the exhaust housing can reach temperatures in excess of 950°C. Water cooling the bearing housing helps to prevent this temperature being transferred into the engine oil. Also, by stabilising the overall temperature, it is not always necessary to allow the turbo to cool before turning the engine off. On our race cars, we always monitored the turbo temperature, and would not turn off the engine until this was below 450°C. In a race environment, the water-cooling pipes were considered as a potential, and unnecessary water leak.
Sounds like if you let the heat dissipate for a few seconds before you turn off the car you should have no worries.
Brian
Brian
Vive le Prole-Ralliat!
